howarmat
Trusted Member
I have to say that battery life is incredibly poor on my dinc. I love the phone otherwise but it has gotten out of hand - progressively worse as time goes by.
After the first month I couldn't make it past about 3pm without a charge.
I gave in and bought a 2150 battery with the ridiculous hump about 6 weeks ago and now low and behold I can't make it past about 8pm before i get the 14% and then 9% low battery warnings.
I charge at night, phone off, no bumping and only in the car when needed.
Still running factory 2.1, I talk for about 60 min a day, manage the radio connections religiously, do about 100 text and another 100 emails on it daily. I don't have many apps that run, and expect worse battery life when running pandora or slacker - which I do rarely - or google maps with the GPS on.
I keep thinking the battery should condition itself but this has gotten crazy.
Anyone else experiencing the same crappy battery life?
TIA
stop running the task killer on froyo and see what happensWell I just got my DINC on Friday so I'm pretty sure mine is in the battery maturing phase that all these batteries go through at first. However I wish I would have known that Froyo would kill my battery. I would have left it on 2.1. Anyway to downgrade?
touche lol...kill the phones functions. less function less batteryYeah normally using some sort of power management helps a power hungry powerful device last longer. Especially turning off or limiting services you don't need or aren't using.
So, after about 2 hours unplugged this morning, battery is down to 65% with light email and internet usage. When I go into spare parts and check partial wake usage, I see that some process called "UID 10004" is at the top and responsible for about 95% of the usage. Google has been no help, so I turn to you all. Any idea what this process is and how I kill it?
Any help here would be appreciated. Anyone seen this before?
Yes the bump helps every time. And I always bump...not just once then never again. If I charge I bump. I change my brightness lower only when I'm low and know won't be able to charge soon enough. I set my phone to unlocked w the app unlock...and set screen to sleep at 30seconds. I always hit the power button to put screen to sleep whenever done doing what I'm doing...even if set to stay awake when charging. I use minimal widgets that require updating on the home screen like news weather coupons etc. Instead I just ad the app icon to pull up...like where which I only use for traffic info...I try not to use multiple weather apps...but like the bug bc I can tell enough from the top status bar. I don't use a task killer other than the HTC running services. I either ring or vibrate but never both and quiet ring when moved...also set led notification off to all ... so doesn't flash for anything. Never turn WiFi off or 3g but Bluetooth always until needed. I agree that turning these on and off frequently is like turning the car off to save gas when leaving it running safes more bc starting the ignition takes a lot of gas...also like air conditioning....instead of turning it on or higher lower to save money, leaving it at 60 or whatever costs less. Like driving on the highway...highway miles...get a lot more. I have an extra standard 1300mah backup jumped fully charged usually always on me...and rarely now even use car charger. I too don't call and text often...but use navigation and maps a lot...and that's where car charger comes in handy. When using latitude in the city , the extra battery is essential.
Charging how often you want your accounts, and apps to update and sync is subjective...can turn off auto sync. Have found that verIzon backup is useless. And don't need extras like FB syncing etc.
Have multiple Google accts...turn off notification in status bar...especially if using gmail icon notification. Manually refresh when needed...etc etc...
My one question I have is about setting animations...I don't know what that means and how it applies here...but maybe turn off all animation or show some could help...
Also my ringtone notification sounds are peaceful and nothing to crazy...nothing long and loud...a lil ding is fine. Or you could turn that off in exchange for led flash notification ...but only one needed if st all. I like usi ong the features of my phone tho...so if I have the backup battery and car charger and am fully charged...ill have a disco party on this thing loud and lit up never sleep live wallpaper and let it ride....
Thanks everyone...lemme know your thoughts if I am wrong or shouldn't do something or should be doing something or if I just suck at life
Btw the apple store wasn't fond of me when I challenged the employees and raced the iPhone...of course they whipped out the top of the line one...
And got smoked....by my boy...he goes wow that's incredible....I said...funny...that's what his name is...
Go figure....ironic huh. So where are all these geniuses you speak of...at a bar...no wonder...
I get it now....
And we left...as ninjas
M
