1. easy1jay's Avatar
    I have a HTC Droid Incredible and since I don't use a Bluetooth headset and there unfortunately isn't an integrated car mount for the phone (yet?), I am curious if there is a way to automatically turn the speakerphone on when the phone is plugged into a charger and then turn the speakerphone off when its unplugged? Can this be done in the settings or is there an app for it?
    I realize I can activate the speakerphone after the call is answered, but I really don't want to be tapping my phone more than once when a call is taken while driving.
    Thanks.
    06-21-2010 02:14 PM
  2. TheReclinerJockey's Avatar
    Have you tried the Car Mode app?
    It puts all calls to speakerphone when you enable it. I'm not sure if there's a setting for plugged/unplugged but at least it's still easier than answering then putting on speaker.
    Settings Profiles also lets you do this, so if you made a profile for when the car is charging it would do it automagically
    06-21-2010 02:53 PM
  3. mclarryjr's Avatar
    There is no setting to have it answer in speaker phone while plug in, and I haven't seen an application that would help you
    06-21-2010 02:57 PM
  4. newdroidnewb's Avatar
    I completely agree with the "Settings Profiles" app from the market recommendation. Its a great app to have for stuff like that and would really work for what you are trying to do.
    06-21-2010 05:56 PM
  5. easy1jay's Avatar
    Awesome, thanks for the recommendation. I just installed the "Setting Profiles lite" app, and created an On Charger profile to switch on speakerphone and keep the screen on which activates only when the phone is plugged on. Works perfectly.
    06-22-2010 08:09 PM
