As far as I know, you are able to use your GPS without a 3g connection. For example in a plane 40,000 feet in the air a 3g connection is not possible but a gps connection is. The only problem is that Google maps is not stored on the phone but stored on their server which means you need a 3g connection to load the content.
I'm wondering if there is a simple app where the map would be stored on the phone. It would be nice to see where you are in the sky when flying from place to place. I would appreciate if someone knew an app that would make this possible.
Thanks,
Sam
Thanks,
Sam
