1. jharo's Avatar
    I'm having problems playing music over bluetooth to my LG HBS-250. I'm able to connect and make phone calls, but I can't get Slacker or the media player to play over bluetooth. Anyone have an idea?
    07-07-2010 02:37 PM
  2. crzyworm623's Avatar
    Try,
    menu
    settings
    wireless and networks
    bluetooth settings
    Then longhold on your device, listed under "bluetooth devices"
    Options
    Make sure under profiles "media" is checked
    07-07-2010 06:24 PM
  3. jharo's Avatar
    Thanks, I tried that. I might try an old BlackBerry trick...battery pull.
    07-08-2010 11:34 AM
  4. jharo's Avatar
    Ok, so after a battery pull, I now lost the option for media audio. Damn!
    07-08-2010 01:07 PM
  5. crzyworm623's Avatar
    forget the device and re add it
    07-08-2010 08:39 PM
  6. jharo's Avatar
    BTW, I fixed this problem. I had to uncheck the media audio option, then recheck it.
    07-21-2010 09:58 AM
  7. johnhboyd's Avatar
    Try,
    menu
    settings
    bluetooth settings
    Options
    Just tried this, and I don't have "media' listed under options. Only Connect and Phone.
    09-11-2010 08:42 AM
