1. CSI Guy's Avatar
    If I am going into a meeting, is there a way to put the phone on silent quickly? On my DX I just turn the volume down to its lowest level and it goes into vibrate mode.
    08-06-2010 04:07 PM
  2. BSG75's Avatar
    Same thing for the Incredible. Is yours acting differently?
    08-06-2010 04:28 PM
  3. Kitchen42's Avatar
    Yeah. I either do that or hold the power button for the menu. You can use the volume changer to change it to silent or vibrate. Same with the menu that pops up when you hold the power/top button.
    08-06-2010 04:32 PM
  4. CSI Guy's Avatar
    Oh Ok just got it and charged up and did not know that it acted the same way to put it on silent. That goes for notifications also?
    08-06-2010 04:39 PM
  5. BSG75's Avatar
    I would expect it to work almost identically to your X. I'm on 2.2 and in that you need to manually set your notifications to be the same volume as the ringer. If you are still on 2.1, the notifications should be the same as the ringer by default.
    08-06-2010 04:55 PM
  6. easy1jay's Avatar
    HTC has also included a widget for this in Sense on the Incredible.
    Add widget > Settings > Profile
    If it's not there, at the top of Add widget, select "Get more HTC widgets" > menu key and select to download more HTC widgets.
    08-06-2010 06:48 PM
