Incredible's radio???
L_Boogie820
186
3
I just got my incredible today. Great phone and almost makes me feel as though Im cheating on my blackberry. :(. anyhow, in places i would get 5 bars on my BB, im getting like 2 or 1...in and out of 3g. In the hospital I work in, they put cell signal boosters for verizon phones only because they have a partnership with them. with my BB, if i was in the OR, i would have 5 bars 3g...i was only getting 1-2 mmmaaayybbbeeee 3 and going in and out of 3g. Issue?
davidnc
Super Moderator
Moderator
Jun 8, 2010
8,905
517
113
Seems like the bars are not as synced with the actual numbers on the incredible .For example on my old Blackberry 8330 my signal number would show -80dBm and 5 bars when my Incredible shows -80dBm it shows 2 to 3 bars.The DX signal when -80dBm shows 5 bars .
I did have a signal issue when I first got my Incredible and called vzw they checked out what PRL I had and said I was on the wrong one and actually switched it for me , or so they said , ha :p
They said it would take maybe 24 hrs to kick in. I dont know about all that but I do know ever since my signal as the same is with the DX and about same as blackberry was , sometimes better even. :D
herbmmm
175
Just got back from tech support at our local Verizon store and he did something that has definitely helped my reception(Bars are the same but reception is better)! He went to phone and dialed *#*#4636#*#* this brings up a screen that includes Phone Info. At this point click Menu then select Radio Band, a force quit screen pops up(this is normal) click ok then scroll down to CDMA Auto then hit Home! Reboot! That's it!
an_icon
74
I did this and it seems to make reception better!!! will make an update in a few days to give feedback , but made a few calls and seems to be better call quality. :D
mikestorm
357
28
Apple's antennagate prompted me to ignore bar comparison and compare signal strength instead. I compared my Incredible (0-2 bars) with my GFs BB Curve (4-5 bars) and the signal strength was identical (-89dBm).
This suggests the bar algorithm on each phone is different. As such just looking at bars is not a consistent comparison. Hope this helped.
L_Boogie820
186
3
Thanks. Makes sense. :)
Qazme
2,703
26
You guys do realize with a digital cellular system 1 versus 5 bars means nothing right? With digital it either works or doesn't. It's not analog where you have static, distortion, etc etc. Instead of worrying about bars think of how many calls you have dropped. If none, then why worry??
L_Boogie820
186
3
for me, its a pet-peeve. everyone has one, right? I did download "True Signal" and yes, youre absolutely right, 1 bar on the native signal reader is 4-5 on True Signal. Ive had a BB for so long that when it says 5 Bars, it shows exactly that. Although I DID do that *#*#4636#*#* and that definitely helped.
edarchitect
17
Another way to improve reception is to update roaming. Here are the instructions from Verizon:
1. Power on your Verizon Wireless phone.
2. Dial *228 from your home digital coverage area, followed by the SEND key.
3. When prompted, press option #2, to update your phones roaming capabilities (This process may take up to 2 minutes).
4. Once completed, a confirmation message will be played, and a message will display on the phone screen.
Qazme
2,703
26
Can the 4636 change mentioned above be undone?
Yeah goto menu --> settings --> Wireless and Networks --> Mobile Networks. Make your change. This is the way to do the same thing as 4636 but without the need to look "knowledgeable" like a Verizon Tech that needs to show how much they know......
KB3MMX
387
6
The HTC Incredible's signal bar indicator isn't calibrated to show as many bars with the same signal as your blackberry was. It's a ongoing issue that is taking forever to get a update that adjusts the indicator to correctly show signal bars.
Try this app: "Real Signal"
Set your 5 bar setting at -80Dbm
4bar @ 90dbm
3 bars @ 95dbm
2 bars @ 100dbm
1 bar @ 105dbm
F34R
F34RTEHDR01D
Jul 8, 2010
361
21
I just got a Dinc, and I'm just going from 1x to 3G constantly, never better than a -90dB, even though their coverage map shows me in a good area. :(
Stevez48
175
3
I have a signal strength of -74 dBm and it shows 2 bars. Is -74 good? I know nothing about signal strength...lol I am assuming since -80 is 5 bar and -90 is 4, then my -74 is real good?
Revolutionary
876
21
You are not actually changing anything when you do the 4636 with force close routine -- just "resetting" the selection. So there is nothing to undo. If you experience a problem (such as no longer getting EVDO Rev. A), just reboot, and if that doesn't fix it, do the 4636 routine again.
Apr 26, 2010
4,335
258
83
Couldn't have said it better.
It's all marketing....
akbarramadhani12
