1. nneptune's Avatar
    Okay.. so, I'll get a notification that I have 11 apps to update.
    I start updating them one by one, and realize I'm on the 3G network, when wi-fi is available.
    I go to the page to turn on the wifi after installing about 3 of my apps.
    However, when I hit Notifications, it no longer shows what needs to be updated.
    So, I end up waiting days until I'm notified again.
    There's obviously a better way than this.
    How can I update the remainder of the apps that need updating?
    Is there a way to get to the previous screen, or a page that shows what needs updating once you veer away from it?
    I just like to keep things updated. Knowing there are 8+ apps of mine that could be updated is sort of bothering me.
    Any help? Thanks!
    08-21-2010 07:16 AM
  2. rpfarrah's Avatar
    Turn off wifi and update all your apps. Turn on wifi when you need / want it.
    08-21-2010 07:39 AM
  3. EvanJ18's Avatar
    When you get into the market. Menu button > downloads. It will say what has an update. Check daily cause you rarely get a notification.
    nneptune likes this.
    08-21-2010 07:50 AM
  4. nneptune's Avatar
    That's exactly what I meant. Thank you!
    08-21-2010 09:01 AM
