1. monkeymisfit's Avatar
    My Inc will not turn on and I have no charge light. Was just shutting down my phone to reboot in recovery mode, and it will not turn back on. The battery said it was at about 17% when I shutdown. Any help?
    09-23-2010 09:16 PM
  2. PvilleComp's Avatar
    Charge it up. Try booting it up again after giving it a charge.
    09-23-2010 09:25 PM
  3. monkeymisfit's Avatar
    Thanks it worked out. I did a battery pull the first time it happened and got nothing. Let it sit on the charger without a light for a little bit, did a battery pull and it turned back on. I just rooted a few days ago and flashed the redemption rom, flashed the INCredible REVOlution theme yesterday, everything worked out great. So I was thinking I would change the flash screen, that was the last thing I was trying to do when I thought something went wrong. But everything is good to go.
    09-23-2010 10:11 PM
  4. PvilleComp's Avatar
    Happy to Help
    09-23-2010 10:29 PM
