I was wondering if there was a free green circle battery icon to replace the stock battery icon in the notification panel. I am not rooted.
Have to tried searching the market for "circle battery icon"....It'll probably bring up a lot of apps to search thru but if its there you'll find it
I'll be happy to root your phone
If I lived in Miami, I'd take you up on that offer!
so if you ARE rooted, is there an app i can install the replace the current battery usage icon? i would like one that shows the battery percentage instead.
someone modified a battery app to have the circle style. Keep in mind it will not replace the default battery indicator but add the circle in addititon. You would have to root to replace.
thanks to the cool peeps over at XDA forums
[APP] 27-OCT-2010 Circular battery Indicator with % (No root required) - xda-developers
