OK here's my scenario I have a non rooted incredible that I use a TON. Yesterday when I was working from home I ran the battery down to about 15%so I charged it for a little while unplugged it and then used it again. Later that night as I do every night I turned it off to fully charge it for the evening. It charged but later on that evening I needed to go back to it for something and I noticed that half of my apps are not working. The pictures on the icons are now gone replaced by a generic android symbol. I can't even access the market, I called verizon and they said the only thing I can do is move my pics to my SD and factory wipe the phone. I really don't want to do this cause then I will loose everything I have in there which is a lot. The icons are still there but when I try to launch them it says "The linked program is no longer installed on your phone". Thought I would run this by everyone here first before I did the factory reset. This is really upsetting anyone else have this happen to them?
Thanks,
Keith
Thanks,
Keith
