1. anon(6936)'s Avatar
    Does the Incredible have it like the Nexus One? Can't find that detail anywhere.
    04-19-2010 12:26 PM
  2. CrackMonkey91's Avatar
    That would be so cool if it did have active noise canceling, i did not see them advertise active noise canceling for nexus right away so some one tell me if the incredible has it?
    04-19-2010 12:37 PM
  3. draken's Avatar
    Haven't seen it on any of the leaked or official spec sheets, so I'd say no.
    04-19-2010 12:57 PM
  4. AndroidJunkie91's Avatar
    I would say no as well. Think it just has one mic at the bottom.
    04-19-2010 01:00 PM
  5. Syco54645's Avatar
    I really hope so but I think they would have mentioned it by now...
    04-19-2010 03:23 PM
  6. johnny99's Avatar
    Hard to believe that an Android 2.1 phone does not come with noise cancellation. Speech-to-text is much less reliable without that feature.
    04-19-2010 03:30 PM
  7. anon(6936)'s Avatar
    I just figured after the Nexus One, all new HTC phones would have it. You can never have it all can you?
    04-19-2010 10:42 PM
