1. crack_wag's Avatar
    i have a samsung fascinate and i try to update by odin... but something went wrong... now i cant use my phone,when i turn it on appers an image on my screen, its a phone, a triangule and a pc... i dont now how to fix it, i tried to put two diferent roms with odin but it didnt work, does someone knows how to fixit?? i dont want the cellphone to use as cellphone... just to use over wifi... thanks...
    note: i watch some tutorials where the person who was installing android used odin... and went he/she conected the phone to the pc in odin appers COM:6 and when i conect my cel appared COM:3... i dont know what it means...
    08-11-2011 07:28 PM
  2. Jmac9's Avatar
    Soft brick.....not a problem, don't panic. Go to droidxcons stickies above
    http://forums.androidcentral.com/ver...g-forum-2.html
    Make sure you are following the odin steps exactly.
    08-11-2011 10:20 PM
