Odin the cwm all unless you are doing a MTd, cm7, Aosp rom.
Which method do you use if you want to use a CM rom? I tried for days and never could see anything in any stickies saying that cwm all would not work with certain roms. A link to the right sticky would be greatly appreciated.
Cheers,
Dave
Cheers,
Dave
ok well i cant figure this out at all...i did what you said and tried 515 other ones...it just keeps saying telling me the siginature isnt working
No problem at all...first problem is that .tar files are used with Odin not cwm.im am new to this but it cant be this hard...i did a factory reset and wiped everthing...thank for the help by the way
i think so...will you explain it to me so im sure in doing it right...I have downloaded like 4 different tar files and still nothing....it the same thing...when i get to red I go straight to install from the sd...then i select a zip to apply then i go to the bottom of the screen and click on update .zip....then every time it reads siganiture verification error....installation aborted
ok so i dont need to apply the update file to cwm...it is already there...I just need to find a rom and replace that with the update file and ill have it
