I have read everything I can find and still cannot get this phone rooted....Please HELP me!!!!!
This is what keeps happening....
I have tried mounting the phone, I have installed the updated drivers but I don't know what I am doing wrong.
I feel like an idiot and I am sure it is something stupid but would appreciate any help you guys could offer.
* Testing if your device is connected
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I5008ef19388 device
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
468 KB/s (0 bytes in 1867568.003s)
91 KB/s (0 bytes in 26264.000s)
361 KB/s (0 bytes in 196521.000s)
17 KB/s (0 bytes in 5392.000s)
5 KB/s (0 bytes in 281.000s) Does this look right???
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 19:48:19.95
** Successfully exploited, installing permanent root files and deleting temp fi
es
error: device not found
* Restarting your phone now.
* Complete
I5008ef19388 device
* Turn On Debugging
* wait
es
* Complete
