difference between LV and SV in voodoo rom
denzillion
51
Hello
Can someone enlightened me by telling me the difference between LV and SV voodoo rom in lagfix procedure? I used the SV 1200 but I don't like how the setcpu will jump from 800 to 1200 on top end. I don't wanna overclock to 1200, so I am thinking of reflashing back down to 1100 or 1000 voodoo rom. But I have no idea what the difference with those voltage packages. Thanks.
NOsquid
539
70
LV is just a little lower voltage for better battery life. Some phones are unstable at low voltage, others are fine. SV is same as stock.
denzillion
51
I reflashed with LV 1000 bc I really don't want to overclock. So far its stable. What kind of symptoms should I look out for instability being a LV rom. And what kind of battery life is expected with LV?
Apologize for all the question. I am so android newbie. Converted from blackberry bold. Thanks.
ragnarokx
6,915
1,696
Low voltage has the potential to cause lock ups that require a battery pull. If you don't get any of those and everything else seems stable then you're good.
denzillion
51
I am back to SV 1100, smallest overclock mode. LV was stable but I can see the choppyness in screen and icons movements. I am happy with this. Thanks all.
kemberley1
