1. Froalskiner#WN's Avatar
    Hi,
    Running superfast and superclean. Today I noticed wifi tether doesn't work anymore. anybody else see this problem?
    Sent from my SCH-I500 using Tapatalk
    11-24-2010 11:43 PM
  2. Froalskiner#WN's Avatar
    So the version I downloaded from the market didn't fully support the Fascinate so i had to grab it from the code.google.com site here
    Downloads - android-wifi-tether - Project Hosting on Google Code
    Looks like the version the market has is the stable version that doesn't have the SF on it's approved list...looks good now.
    11-25-2010 02:03 AM
  3. Sta11i0n's Avatar
    Exactly where I would have referred you to. I have not had any luck with market versions of the app.
    11-25-2010 02:27 AM
  4. namebrandon's Avatar
    If you're using windows 7, you may need to upgrade WiFi drivers.. For whatever reason, DI01 tether (barnacle legacy) worked fine, then after DJ05 I had to upgrade my windows WiFi (intel) drivers to get tethering to work once more.
    I'm now using pre14, I like it a bit more than barnacle.
    11-27-2010 11:52 PM
