I'm trying to get into CWMod but all i get is this new menu. I've used cwmod recovery several times and this is the first time I've seen this menu. Its similar to Clockwork but the only options are
reboot system
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
In the middle is a triangle turned sideways with yellow exclamation point and "manual mode" in yellow letters under it.
Any ideas?
reboot system
Any ideas?
