help!!!rooted samsung fascinate error when trying to install superclean
DroidXcon
11,102
3,392
please have samsung fascinate rooted. when i try to run update.zip get error could not validate. please help
Hey wester, first off , welcome to Android central..... couple questions, do you have the verizon fascinate? and also did you flash Clockworkmod recovery using odin
if you did not then follow the directions in here
http://forum.androidcentral.com/ver...ckworkmod-recovery-return-stock-use-odin.html
if you are on DI01 use sections 1 of the clockwork post
if you are on DL09 use either section 2 or 3
MarcosVo
