03-20-2011 03:39 PM
484 ... 17181920
tools
  1. T3CH9ICIAN's Avatar
    ive got it dl on to pc does it just get moved on to sd card like a theme then from there how do i apply it to my phone ?
    03-18-2011 09:48 PM
  2. JaeKar99's Avatar
    sure ill give it a try what all goes along with testing something ? what am i looking for or reporting ? apk ? android package kernel ? what does it involve to get it on my phone simple flash method like a theme ?
    Copy to your sdcard and install like you would any other application. Don't flash. You should install via your file manager (Root Explorer or just My Files) Click on the file name "Purplecomb-signed.apk" and the system should ask if you want to install - you do.
    Report back any errors you get..
    If you get a good install report back any graphical hiccups or other issues.
    T3CH9ICIAN likes this.
    03-18-2011 09:50 PM
  3. T3CH9ICIAN's Avatar
    ok give me a bit and ill get it going here
    03-18-2011 09:51 PM
  4. JaeKar99's Avatar
    Given a clean install.. You should be able to find a live wallpaper with the name of Electric Purple Honeycomb.. make that your wallpaper of choice.
    03-18-2011 09:53 PM
  5. T3CH9ICIAN's Avatar
    the live wallpaper is nothing but a white screen no action color or anything
    03-18-2011 09:55 PM
  6. T3CH9ICIAN's Avatar
    the wallpaper name is Electric Purple Comb the small box image next to it on the left is a droid with custom lwp underneath but only a bright white screen when applied or any setting changes that are there
    JaeKar99 likes this.
    03-18-2011 09:57 PM
  7. JaeKar99's Avatar
    Were you running any live wallpapers previously?
    03-18-2011 09:58 PM
  8. JaeKar99's Avatar
    Yep - I was afraid of that - you and I just got our first taste of a beta version.. Sorry man. I will have to pull the link down and try again..
    I really appreciate your time and investment. I will definitely knock again when I get this up and running.
    To un-install go to your task manager and select package and the wallpaper will be there... uninstall and you will have to reset to the wallpaper you had previously.
    03-18-2011 10:01 PM
  9. T3CH9ICIAN's Avatar
    no i wasn't i just had a standard wallpaper but after it came up white i changed to a diffrent live paper and its worked my grassy day to night works as well as many others hey im a very patient person id love to b one of the first sunning a paper like that its an amazing image i love watching my boot up thank u for the work ur putting in i love this forum nothing like it
    03-18-2011 10:01 PM
  10. JaeKar99's Avatar
    Ready to try some Livewallpaper again? - I got the issues resolved with the white screen (hexidecimal off) - Any how here is the Electric Purple Honeycomb version 3 - Link
    Installs the same as the first version. When you set up the speed; I had good images above 45 frames per second... the size - Large.
    Welcome to try it out. Please offer feedback..
    03-18-2011 10:54 PM
  11. T3CH9ICIAN's Avatar
    im running it now its absolutly beautiful on medium it has a glitchy upper bar like its scrolling over but im running it big and at 80 to 85 fps its very smooth there a lil blurry but im sure not easy to make nice and sharp looks great so far thanks
    03-19-2011 12:21 AM
  12. JaeKar99's Avatar
    Thanks for the feedback. I tried to get the highest def version of this boot animation.. that is likely the best it is going to be. This is the boot animation for the Moto Xoom.. I pulled a copy of the original of the internet and will try a couple of run throughs. [FYI: The live wallpaper you requested and I produced is available in the Market from free to -> $1.25 - same version you have]
    There is an option to adapt any boot animation (or shutdown animation - in png format) to a live wallpaper. - I will keep making a few examples and when I have a good handle on the software I will teach everyone how to use it.. It is not scary hard to use, just finicky and takes some patience.
    Thanks again man!
    03-19-2011 07:22 AM
  13. cwd500's Avatar
    My market is trying to update Pandora and facebook, but they won't install. Is it because I have them apps themed with nitro honeycomb?
    sent from my super clean 2.9.1 voodoo fascinate
    03-19-2011 08:47 AM
  14. JaeKar99's Avatar
    Unlikely due to being themed. Go to Settings> Applications>Manage Applications> All (scroll down to Market)>Select Market and clear data and if there is a cache clear it.. (try to update again) - If you still have issues you can go back under Applications and market and uninstall updates and try again..
    There have been times where a simple reboot of the phone clears the offending issue and my apps update.
    03-19-2011 09:06 AM
  15. JaeKar99's Avatar
    I have been toying around with some software I discovered and found that a Live Wallpaper can be produced from a boot animation file.. it is fun once you figure how to appease the software..
    Thanks to T3CH9ICIAN for the help with the beta release of the Xoom boot.. not the best definition. - Still in progress.
    Here is my first real release - Kanged Blue Particles (higher def) Link
    Install like a standard apk file - copy to sdcard, go through file manager of your choice - install. Look under (soft) Menu>Wallpaper>Live Wallpapers..
    Set your size settings to "Big" and then adjust your frame speed to your liking... enjoy.
    End Goal: Teach everyone to do this...
    03-19-2011 10:06 AM
  16. Landshark's Avatar
    Unlikely due to being themed. Go to Settings> Applications>Manage Applicatoins> All (scroll down to Market)>Select Market and clear data and if there is a cache clear it.. (try to update again) - If you still have issues you can go back under Applications and market and uninstall updates and try again..
    Well, in the OP for the Nitro Honeycomb theme, nitroglycerine33 said if you have any of the stock apps for the ones that are themed, you should uninstall them before flashing the theme. So sounds like maybe this could be the case since you have the themed apps and not the stock apps? Not sure.
    03-19-2011 11:04 AM
  17. T3CH9ICIAN's Avatar
    Ur welcome thanks for the help wit it I'm running good at 60fps little bit of lag sliding screen to screen but not bad again thanks is the latest link the same yet higher def ? can I dl direct to my phone ?
    03-19-2011 11:23 AM
  18. JaeKar99's Avatar
    Not the same. Totally different video sequence. It is higher def wallpaper - (It is the Wallpaper version the Andriod Particles Blue) boot animation. Still looking for a very high def version of the purple honeycomb.
    If you use a browser you should be able to download to your phone and install like any other apk.
    03-19-2011 02:14 PM
  19. JaeKar99's Avatar
    Good catch Landshark.. I was using NitroHoneycomb without the apps and had issues with the market not updating any of my installed apps.. would force close after opening. I was able to fix permissions and uninstall updates that resolved that issue. Guess I was not sure what direction to go with it.
    I would guess that an uninstall of the market apps and reinstall would be in order.
    03-19-2011 02:32 PM
  20. T3CH9ICIAN's Avatar
    this is a screen shot of the lockscreen in motion at 60 fps
    03-19-2011 02:38 PM
  21. JaeKar99's Avatar
    this is the lockscreen in motion at 60 fps
    Looks pretty good. I know what you mean by blurry.. When I ran it it was doing the same thing.. The png images were adjusted in size to be a great boot animation.. I have the original Xoom boot which is broader but has the same definition... May still appear blurry at higher frame rates.. I will compile it this afternoon and see what it looks like.
    03-19-2011 02:50 PM
  22. T3CH9ICIAN's Avatar
    awesome trying to b helpful im am happy with it though it is beautiful looking
    03-19-2011 02:57 PM
  23. JaeKar99's Avatar
    This is as good as it will get. Smaller memory footprint - 25% reduced. Resolution is as sharp as I can get it until I dig into the png files... Let me know which version runs better for you.
    Here is version four.. Link
    Enjoy
    03-19-2011 03:45 PM
  24. T3CH9ICIAN's Avatar
    Enjoy
    the first one purple honeycomb 3 is very smooth and fluid were as the kangled electric purple 4 has like a pop effect as the combs disperse which looks great also! the quality and definition is very minimal difference to my eyes i am running kangled at a much lower speed of 30fps compared to purple 3 at 60 fps to calm the pop effect out a bit it still is smooth and nice personally i prefer the fluid feel of the purple 3 to the popping feel of kangled 4 but both are awesome and quality is great if the fluidity of the purple 3 was on the quality of the kangled 4 that would b were its at looking smooth as silk but running wise they both are running great smooth images as my wallpapers they were about equal for everything running with them such as the contacts list with the transparent backround the wallpaper moved well and the scroll was really fluid with both but alil less lag on kangled 4 awesome work put it glad to check em out for sure gonna keep running purple 3 for now any more u want to have me look at let me know i enjoy giving an opinion and if u looking for something else in the way of an opinion let me know what u wanna know or look for
    03-19-2011 06:41 PM
  25. JaeKar99's Avatar
    Thanks a lot for the feedback. I helps. I need those extra eyes to see things from a different perspective.
    I built them for you and anyone else who wants to try them out. I will absolutely keep you in mind as I develop apps, animations, and themes.
    J
    03-19-2011 08:39 PM
484 ... 17181920
Tags for this Thread
