03-20-2011 03:39 PM
484 ... 34567 ...
tools
  1. Landshark's Avatar
    Right, it says that EB01 leak is not deodexed. Nothing about the 5 lockscreesn needing to be on a deodexed rom. I did not take an add on as being a theme. My bad!
    No problem. It takes a while to get all this lingo down - radio, modem, kernel, rom, etc. Now you've got DroidXcon throwing around .bin files and Winrrar, and a lot of it is still greek to me. I'll send a PM to JaeKar and see if he can add in the word add-on's to his warning.
    02-15-2011 02:23 PM
  2. JaeKar99's Avatar
    I will be updating through most of today.. Will update that first.
    Landshark likes this.
    02-15-2011 03:15 PM
  3. Landshark's Avatar
    A warnng to anyone who downloaded the A Touch of Blue theme between the time he added the sbrissen 5 lockscreen mod and late this afternoon, DO NOT try to use the epic lockscreen it will put your phone in a force close loop of hell. Bendbowden fixed the issue and confirmed the epic lockscreen now works. So if you downloaded Touch of Blue between yesterday afternoon and this afternoon, you are going to need to replace the theme before you try to use the epic lockscreen.
    JaeKar I'm going to PM you but if you see this before I PM you could you make a notation in post #1? Thanks.
    JaeKar99 likes this.
    02-15-2011 06:57 PM
  4. JaeKar99's Avatar
    Put an update on post #2. Thanks. I didn't even see that develop.
    Thank you sir! You are a fantastic spotter!
    02-15-2011 07:08 PM
  5. vluc's Avatar
    Loaded Superclean 2.4 nv, now I have the 5 lockscreens!
    02-16-2011 08:27 AM
  6. JaeKar99's Avatar
    Yup it was included in SC 2.3..
    Be aware that if you flash a theme without the 5 lockscreens included it will over write that option with with the lockscreen(s) that are packaged with the theme.
    Flashing some battery mods will do the same.
    02-16-2011 08:32 AM
  7. Jgonzo1299's Avatar
    So, I have the Full Stock Froyo Leak+root+Froyo Clockworkmod on my fascinate. Debloated it myself via Titanium backup freezing.
    Im assuming i need the deodexed version of EB01 if i want to install one of these themes, correct?
    02-16-2011 11:04 AM
  8. Jgonzo1299's Avatar
    NVM i didn't read the big bold red note at the first post of the sticky. FAIL
    02-16-2011 11:38 AM
  9. JaeKar99's Avatar
    Unless you brick it .. then give up. - That is a FAIL...
    So far so good.
    02-16-2011 12:54 PM
  10. BigSwoe's Avatar
    Several of the theme previews show some terrific wallpaper that is not actually part of the theme. Any tips on where to find these?
    02-16-2011 12:56 PM
  11. JaeKar99's Avatar
    Some of the developers will post the wallpaper on the original post page, with an option to download. I include a link to that page in the developer name.. If they do not include the wallpaper (or a link) I may be able to chase it down.
    BigSwoe likes this.
    02-16-2011 01:01 PM
  12. BigSwoe's Avatar
    Sweet. Thanks. I'll give that a go.
    02-16-2011 01:05 PM
  13. willenium_1217's Avatar
    I am going to put a touch of blue for my theme, I am way excited! But if I wanted to return to the stock "theme" would I have to reflash the original ROM or is there a theme to flash back to stock?
    02-16-2011 03:35 PM
  14. JaeKar99's Avatar
    You can flash the base ROM on top without wiping the phone (do clear the cache), and that will work also... only if you are using the same base ROM...
    Another way to return to stock is to back up your current rom, flash what you want and if you don't like it just use the back up to return to where you were. This will take more time and will take you back in time. I use this method if I have flashed some extra mods battery mod, clock removal, charge notifications, etc.. and you are getting some compatibility issues - forced closes.
    There are no 'stock' themes out there just some close approximations.
    willenium_1217 likes this.
    02-16-2011 03:45 PM
  15. willenium_1217's Avatar
    Got it. Thanks. Makes sense. Thanks for your help!
    02-16-2011 04:04 PM
  16. tnez21's Avatar
    I've found that if you unzip the theme file you will be able to see what files were changed by the theme. All The files that where changed by theme are located inside the system folder. You can replace these files with stock ones copied from a stock version of your rom and then re-zip the theme folder, flash, and you'll be back to stock. Hope this makes since and helps
    Sent from my SCH-I500 using Tapatalk
    02-16-2011 04:28 PM
  17. Landshark's Avatar
    cfost 88 updated Blackish Storm theme, but didn't include the 5 lockscreens
    EDIT- UPDATE - cfost88 posted in his thread he is working on the 5 lockscreens and should have it done sometime tonight
    02-16-2011 07:10 PM
  18. JaeKar99's Avatar
    Yeah, When I was updating (and preparing to download&flash), the AC posting I looked closely at the zip and took note of two things: the theme didn't have the 5-locks and that he updated his post dated "2/17/11".... tomorrow. Figured he was planning ahead - I updated the AC posting with his date..
    02-16-2011 08:15 PM
  19. Landshark's Avatar
    So he's just playing head games with us then.
    EDIT - I was periodically checking his post tonight and that update on 2/17/11 was there well before he replied to my post adding my name to the list of people asking him to include the 5 lock screens
    02-16-2011 08:19 PM
  20. JaeKar99's Avatar
    I think he, and the other theme developers, are working overtime an a few things are getting missed. Transparent Myst v7 had some issues - hopeful corrected, Touch of Blue - on the 14th, AOSP White is on v8 with continued updates and fixes..
    I think these guys are going balls out and trying to keep the fans happy and may miss a few things.
    I don't think he is playing head games... I hope.
    02-16-2011 08:24 PM
  21. Landshark's Avatar
    I was just trying to be funny anyway. Flipping back and forth between so many threads, just rushed to post that.
    I'm sure those guys are working like mad dogs.
    02-16-2011 08:27 PM
  22. dshep04#AC's Avatar
    So I'm a complete noob at this.. I just rooted my fascinate... how do I get one of these roms on my phone? I'm looking to use the super clean.. can someone help.. sorry for my stupidity.. Thanks!
    02-16-2011 11:55 PM
  23. djlim4's Avatar
    Go to droidxcon's thread titled [odin] fulleb01 Froyo leak
    02-17-2011 12:21 AM
  24. Jgonzo1299's Avatar
    Midnight theme... so many downloads. are they all different parts or are they different versions. whats the difference, aka AOSP vs lock mods etc
    02-17-2011 12:02 PM
  25. JaeKar99's Avatar
    It is like going shopping in huge shopping mall, with people who speak a different language. Until you get a good handle I would recommend that you should check out the developer's OP for details regarding what each offers. I include a link to the OP in the developer name. After spending some time reviewing and shopping you can determine what you like and what you don't.
    Take your time and read/understand all instructions fully. It takes some time to learn the vernacular (lingo). Until then it can feel a bit daunting. Take your time. FYI: AOSP
    Once you get a handle it is a blast.
    02-17-2011 12:20 PM
484 ... 34567 ...
Tags for this Thread
