ThePlasticBling
Sorry for being a noob, but whats the diference between DL30 and EB01? I keep hearing about both of them, but which one is newer and better?
Can you load multiple EB01 themes at once - such as
EB01 Super Dark v1 - New Stuffs
and
EB01 Accurate Battery Options - Chris3D
Or are these meant to be run separate?
And then if I'm on superclean 2.3 voodoo - could I do...
EB01 Froyo Camera.apk Power Button->Shutter Key; Disable Low Batt
Or would I have to be on the deodexed rom for that to work? Thanks.
Is superclean deodexed? Thanks for the quick response.
You should be on a deodexed ROM for any or all of these to work. Some features (battery features) will overwrite other (battery). I think if you flash in sequence: Superdark, then battery, Camera.apk, you should get most features of what you want. I have successfully flashed what I wanted all in the same session with not ill effects... I have lost the 5-lockscreen options of SC 2.3 when I flashed a theme.
It may be trial and error until you get what you want.
I know that many developers are adding in these options as they are released.
Voodoo will not affect any of the theme options but will give you boot animations.
I dl'd and installed the 5 lockscreens. They show up in display settings, but when I select one, it keeps returning to puzzle.
Plain old debloated EB01, no themes, no custom roms
Can't imagine why you would have a problem. you need a deodexed rom to run themes and you are running the debloated/deodexed version so it should work. Let me dl and try running the db/do version with the 5 lockscreen mod and see what happens. Going to take a little while though
Was and's EOB1 release deodexed? Did not think it was, and that might be the problem.
LOL! Gave me a chance to run the backup I did. Interestingly enough, with the lockscreens loaded, my battery color went from blue to teal. After I reloaded the backup, back to blue.
The original stock EB01 leak was not deodexed. If you flashed the debloated/deodexed version or any of Adrynalyne's superclean versions, they are all deodexed. Adrynalyne did not do anything with EB01 stock, just put it out to us as he got it. And every version since then has had further and deeper customization.
Then that is the problem. May need to fix the comment in the first post to reflect the fact that this EOB1 add-on needs deodexed. No mention of that was made so I dl'd it and installed. Glad I could pass something on to others!
Check the fist post of this thread again. Right at the top in BIG red letters.
