im running it now its absolutly beautiful on medium it has a glitchy upper bar like its scrolling over but im running it big and at 80 to 85 fps its very smooth there a lil blurry but im sure not easy to make nice and sharp looks great so far thanks
My market is trying to update Pandora and facebook, but they won't install. Is it because I have them apps themed with nitro honeycomb?
sent from my super clean 2.9.1 voodoo fascinate
Unlikely due to being themed. Go to Settings> Applications>Manage Applicatoins> All (scroll down to Market)>Select Market and clear data and if there is a cache clear it.. (try to update again) - If you still have issues you can go back under Applications and market and uninstall updates and try again..
There have been times where a simple reboot of the phone clears the offending issue and my apps update.
Ur welcome thanks for the help wit it I'm running good at 60fps little bit of lag sliding screen to screen but not bad again thanks is the latest link the same yet higher def ? can I dl direct to my phone ?
Well, in the OP for the Nitro Honeycomb theme, nitroglycerine33 said if you have any of the stock apps for the ones that are themed, you should uninstall them before flashing the theme. So sounds like maybe this could be the case since you have the themed apps and not the stock apps? Not sure.
this is the lockscreen in motion at 60 fps
awesome trying to b helpful im am happy with it though it is beautiful looking
This is as good as it will get. Smaller memory footprint - 25% reduced. Resolution is as sharp as I can get it until I dig into the png files... Let me know which version runs better for you.
Here is version four.. Link
Enjoy
the first one purple honeycomb 3 is very smooth and fluid were as the kangled electric purple 4 has like a pop effect as the combs disperse which looks great also! the quality and definition is very minimal difference to my eyes i am running kangled at a much lower speed of 30fps compared to purple 3 at 60 fps to calm the pop effect out a bit it still is smooth and nice personally i prefer the fluid feel of the purple 3 to the popping feel of kangled 4 but both are awesome and quality is great if the fluidity of the purple 3 was on the quality of the kangled 4 that would b were its at looking smooth as silk but running wise they both are running great smooth images as my wallpapers they were about equal for everything running with them such as the contacts list with the transparent backround the wallpaper moved well and the scroll was really fluid with both but alil less lag on kangled 4 awesome work put it glad to check em out for sure gonna keep running purple 3 for now any more u want to have me look at let me know i enjoy giving an opinion and if u looking for something else in the way of an opinion let me know what u wanna know or look for
Why is this post no longer a sticky? I check it every day and I'd hate for it to get lost in the forums.
I've been running the NexTheme with SC 2.9.1 and it's working flawlessly. The transitions are very nice, and it's very fast. Overall, I love it.
Noob question. Say I want to flash another theme while I'm already running the NexTheme....do I have to revert back or just flash the new theme over the NexTheme?
