03-20-2011 04:39 PM
484 123 ...
tools
  1. JaeKar99's Avatar
    I have relocated the resources associated with this thread to a new thread - > here
    Moderator Please Close this Thread
    Help Index with Links: (currently being added)
    Guide to Fascinate Beginners rooting - Link - Sheepdog Elite
    How to Install and Use Clockworkmod Recovery w/Screen captures - Link - DroidXcon
    How to Use Clockwork Mod Recovery - Instructions, Guidance and Discussion on the use of CWM - Link - Landshark
    How to Voodoo - Instructions, Discussion and Guidance for the use of this kind of kernel - Link - gunnermike53
    How to Improve Battery Life - Guidance, Discussion and Directions to improve battery life - Link - gunnermike53
    How to Install Boot Animations - Instructions, Guidance, Links and Discussion on boot animation installation - Link - JaeKar99
    Apps that are safe to remove after rooting - Link - Cory Streater
    Full System Wipe - Link - DroidXcon
    voghan, afbar1114, vluc and 38 others like this.
    02-02-2011 07:47 AM
  2. JaeKar99's Avatar
    Removed to other location
    02-02-2011 07:47 AM
  3. JaeKar99's Avatar
    Removed to new thread
    02-02-2011 11:08 AM
  4. JaeKar99's Avatar
    Making Room - DL30 ROMs and Themes are located here
    Landshark, curley and sixit like this.
    02-02-2011 05:33 PM
  5. JaeKar99's Avatar
    All resources moved.
    sixit likes this.
    02-02-2011 06:24 PM
  6. JaeKar99's Avatar
    A fix was worked out by Suicide Shift:
    Instructions:
    I found a way to change themes. I tested and found the following:
    If you do your nandroid backup then apply the first theme it will work. If you then restore your nandroid no them backup and apply another it FC's during boot animation and never loads.
    This was NOT a theme issue I found a way around it! The below steps are if you are going from an already installed theme to a different one and you have a clean nandroid backup already...
    So basically and let me know if you need more detail:
    1. Make sure you have a non themed nandroid backup and backup any data contacts sms messages etc...
    2. download your theme if not already on SD Card (duh)
    3. In RED Recovery restore your clean NO THEME nandroid backup
    4. To Prevent the FC loop at boot up you need to Flash your ROM / Kernel again... I flashed my SC2.9 voodoo after restoring my clean nadroid backup
    5. Apply new theme
    6. Boot and enjoy
    Something must get stored by the themes that is not part of the nandroid backup that causes an issue. So between theme changes after nandroid clean restore just flash your current SC.X ROM / Kernel and without rebooting flash your new theme.
    Works for me
    ThePlasticBling and sixit like this.
    02-03-2011 11:38 AM
  7. rapideyemovement's Avatar
    is there a quick way of removing a theme once applied, other than a CWM backup?
    Not that its a big deal, but it would be easier if you could simply disable a theme.
    PLUS!
    DL30 - Matted Blues Engraved 2.5 <--- Link is down
    02-03-2011 01:52 PM
  8. JaeKar99's Avatar
    Unfortunately it is a replacement of theme components not an installation and then being able to turn it on or off..
    Here is a bone bare stock theme: Link This will flash over the theme you have installed.
    02-03-2011 01:58 PM
  9. vluc's Avatar
    DL30 Kernel for boot animation - kanged from XDA -
    I have not tested this kernel. This will work with DL30 - it will afford you the option for using boot animations. It does not accommodate for start up sounds.
    Link - Heavily thank jt for this is his work.
    Thanks, was just going to post on that fact! Installed fine, now have the boot ani, but as you mentioned, no sound.
    02-03-2011 03:31 PM
  10. Sta11i0n's Avatar
    PLUS!
    CWM restore is the quick way. The themes replace system framework files. To get your old ones back, you need to restore them.
    I'm glad it came with a nice preloaded boot animation too
    vluc likes this.
    02-03-2011 04:25 PM
  11. JaeKar99's Avatar
    PLUS!
    Link is up... Thanks!
    02-03-2011 04:37 PM
  12. vluc's Avatar
    LOL, did it? I already had one I used on 09 loaded and ready and that's what I got!
    02-03-2011 07:28 PM
  13. adellc3's Avatar
    I tried flashing the Gingerbread one with the Battery mod by putting it on the sd card via USB, and then downloaded ROM manager and hit Install ROM from SD card. Then it brought me to the green CWM Recovery.. Am I doing this right? And if I am, where do I go from there? I'm trying to learn how to flash these ROMs, and I'm sorry if I'm being annoying about it.
    02-03-2011 11:22 PM
  14. Landshark's Avatar
    I can't seem to download the superdark theme. I click on the link, media fire page opens up, when I click the download button on that page it says processing download, then nothing. No pop up to save the zip file anywhere. Any help?
    EDIT* - Never mind. don't know what was different, but I just tried it again and was able to download it.
    02-03-2011 11:46 PM
  15. Dracolan's Avatar
    I absolutely love the Midnight v1.0 theme! Thanks
    02-03-2011 11:51 PM
  16. AmanteNJ's Avatar
    love it also the only thing i hate is the battery monitor which rounds to 20% ... dont know if its just me or everyone else is experiencing it
    02-04-2011 09:58 AM
  17. JaeKar99's Avatar
    There are some other battery mods out there. Some are buggy and will cause your phone to reboot with the long press on the power button.
    Look here for different types of battery/notification bar options.
    These will work with sc 1.0 where some others will not.
    02-04-2011 10:33 AM
  18. AmanteNJ's Avatar
    using the super dark right now and the battery status seems accurate enought
    02-04-2011 10:44 AM
  19. Dracolan's Avatar
    I don't mind that because this is my first theme and the stock never told me how much battery i had left.
    02-04-2011 07:35 PM
  20. NovaSS369's Avatar
    Question: I have a theme set and when I flash a different one it wont change everything, the widgets stay as the old theme but the notification bar changes, etc. Do I need to flash the stock theme in between?
    02-05-2011 01:26 PM
  21. JaeKar99's Avatar
    You can start with removing the widgets and re-installing them on your desktop.. if that does not help you may have to wipe your cache between themes.
    If you are using the old green CWM this may be contributing to the problem.. to insure a good install flash the new CWM (froyo_cwm.zip) link It has been noted that the original CWM is installing files in the wrong places.
    Re flash the theme that you want to use and that should take care of the issues.
    02-05-2011 03:27 PM
  22. Landshark's Avatar
    I can't seem to get jt's gingerbread theme to work with superclean 1.0. Whenever I install that theme with superclean, after reboot my phone is just stuck on the samsung logo and the phone keeps vibrating. Have to do a battery pull and reboot into recovery to change the theme.
    02-05-2011 03:27 PM
  23. JaeKar99's Avatar
    If you flashed this: Gingerbread Theme for JT1134 Froyo V2 - it will only with with jt1134's Froyo build..
    You need to use: Gingerbread Theme DL30 v3 - it is designed to work with DL30.
    Landshark likes this.
    02-05-2011 03:36 PM
  24. Landshark's Avatar
    Thank you again. Thanked you on the superclean thread.
    JaeKar99 likes this.
    02-05-2011 04:02 PM
  25. Landshark's Avatar
    I can't seem to find jt1134's froyo build. Where can I find it? Thanks
    02-05-2011 06:36 PM
484 123 ...
Tags for this Thread
