1. Red913's Avatar
    Installed this rom from rom manager and my battery dies super quick.any ideas why?
    02-09-2011 03:30 PM
  2. Clak's Avatar
    Could be something you're got running, check to see what is using the most battery power on your phone.
    02-09-2011 04:01 PM
  3. Red913's Avatar
    Android os
    02-09-2011 06:06 PM
  4. luke949's Avatar
    i got the same problem. the battery drains fast with blackhole for me.
    02-09-2011 06:57 PM
  5. Red913's Avatar
    So you never resolved it and switched to another rom I'm assuming, right?
    02-09-2011 07:54 PM
  6. Nytom30's Avatar
    I had the same problem. How i fixed it was the Battery fix on XDA forum and removed Beautiful widgets. Battery life is better now just still not as good as it was with dl09 and stupidfast 12/20 kernel. Beautiful widgets always sucked down my battery, just thought it wouldn't on Froyo but i was wrong.
    XDA link
    HOW TO: Solve Battery Life Issues - xda-developers
    02-09-2011 09:47 PM
  7. gunnermike53's Avatar
    bump
    rion_j likes this.
    03-03-2011 03:04 PM
