I have tried several different widgets, resetting the battery stats, etc., but after installing EB01 my battery seems to fall below 95% very quickly when removed from the charger. With Android 2.1 it would remain in the 95% for a couple hours. I am starting to suspect voltage is the issue.
Can we take a survey of what our peak voltages are when off the charger? Mine used to get to about 4.22 at 100% if I remember correctly now I can only get to 4.148volts at 97% and it has only been off the charger for about a minute after an overnight charge. I'll post more data as the phone discharges. I'll try to get 2 good data points that we can all compare. Maybe 95% and 50%?
