DroidXcon
stupid question here, when you say flash is it safe to assume you mean install 2.8 zip again?
yes sir, in the link above there is a section on flashing zips
Voodoo lagfix is actually: diabled
next boot: enabled
Wipe cache partition? don't see dalvik cache
still reboots to red recovery. I will look for a card reader but I don't think I have one that small
ok, so once I have it downloaded just push it over to the phone? I will need some direction once it's pushed. Also should I push as zip or unzip?
i/o error you can now close terminal. whoops nevermind didn't have card in all the way
still getting I/O error and no files found
I tried pushto. but even if I put it on the other card and put that card in the phone I get no files found. do I need to put it on the orginal card? I had a spare that I tried with the card reader.
if I put that card in the card reader the computer doesn't even see it. I would need to reboot phone and hope for coms or put it on other card which oddly computer does recognize.
You are correct. Mac recognizes it now but...
Desktop/Droid/eb16_voodoo_working.zip' to '/sdcard//eb16_voodoo_working.zip': I/O error
You can now close terminal.
I really appreciate you taking all this time to help with this!
