triple07
So if I use this method could I still use Odin on a PC to go back to stock if something should go wrong? I have access to a PC but my primary computer is my Mac so I'd like to use it for this task.
yes you can most def use odin any time
Mounting system
mount: Operation not permitted
Moving su
failed to copy '/1-click-root-v1.1/Files/rooted/su' to '/system/xbin/su': Read-only file system
Moving busybox
failed to copy '/1-click-root-v1.1/Files/rooted/busybox' to '/system/xbin/busybox': Read-only file system
Changing permissions on su
Unable to chmod /system/xbin/su: No such file or directory
Changing permissions on busybox
Unable to chmod /system/xbin/busybox: No such file or directory
Installing superuser.apk
240 KB/s (196521 bytes in 0.799s)
pkg: /data/local/tmp/superuser.apk
So I'm having some problems rooting my Fascinate. I've tried a couple times and manually deleted the files moved over for rooting. First off when it says " adb connection will be reset. restart adb server on desktop and re-login." Am I supposed to manually restart my phone or do I wait for it to do something? At first I waited for about 15 min and nothing happened so I manually restarted my phone. Then after I did that it waited 30 seconds for my phone to restart and I had to manually tell it when the phone started back up. Then we get to the real problem:
Code:Mounting system mount: Operation not permitted Moving su failed to copy '/1-click-root-v1.1/Files/rooted/su' to '/system/xbin/su': Read-only file system Moving busybox failed to copy '/1-click-root-v1.1/Files/rooted/busybox' to '/system/xbin/busybox': Read-only file system Changing permissions on su Unable to chmod /system/xbin/su: No such file or directory Changing permissions on busybox Unable to chmod /system/xbin/busybox: No such file or directory Installing superuser.apk 240 KB/s (196521 bytes in 0.799s) pkg: /data/local/tmp/superuser.apk
So what ends up happening is I have Superuser on my phone but whenever I try to do something that requires a rooted phone it tells me my phone is not rooted. Anyone know what the problem here is?
When flashing super_frankenclean_2_9_2nv.zip it sticks on Installing Update...
I've pulled the battery 3 times and it still hasn't worked. It keeps sticking to that. It's been on it for 5 minutes now. Is it supposed to take that long?
Just to clarify, are you getting into red recovery?
Now that the official Froyo will be coming out tomorrow- how do we go about updating to that if we choose to? Do we do the standard install without it affecting our rooted phones? Or do we need to unroot, or what?
Let me get this right because things have been pretty hazy on these recent roms being released. If you only have access to Mac there is no way to get a full ED01 experience because you cant flash the modem/radio correct? I'm on SC 2.9.2 and would like to update but I don't see any reason to if I don't get the new radio or kernel.
I left my phone rooted, put back the bloat I manually removed and the OTA updated just fine. It unrooted my phone of course after it was done. Just ran the OS X 1-click root steps again and it rooted the 2.2 OTA no problem.
is there a setting to make the GPS check faster or in a closer mode???
if so where can i see this? I did see it once but forgot how i got to it....
If you flashed any of the superclean roms you will need to flash back a stock rom of 2.1. I'm gonna work with Droid and make a flashable EB01 rom.
Sexy. That would be the only way as of now, correct?
Thats good to hear 1-click-root still worked on 2.2 OTA. What rom were you running before you updated?
