In an effort to spare other noobs like myself a lot of grief, I will recount my experience with installing the Thumb Print Analyzer boot animation from this thread. After spending hours over the course of a few weeks trying to get the animation installed and working properly,and many trials and errors I for some reason long pressed on the bootanimation.zip file I installed at system/media and got a pop-up asking "Extract to sdcard?" I hit O.K. and then deleted the still zipped bootanimation.zip file, navigated to sdcard and copied the un-zipped file to the system/media file where it now appeared in its three separate parts. I then re-booted my phone and watched the bootanimation as it displayed perfectly.
I am glad you got it to work. It appears that the install script was either not putting the boot animation where it was supposed to or it was an old script that was aborting in the newer versions of CWM..
I have repacked the zip file in the new edify script and it should install in any CWM now..
As a cautionary note: Many of these boots are not being hosted by me or my file sharing service. I did not make them, pack them, or write the install scripting for some (many). I provide a link to the files and some are becoming outdated or may be designed to install on other phones..
If you encounter problems please let me know and I can help walk you through them.. Or I can repack and put it up for all to use.
Thanks, J
