Ok I just needed to reboot the phone root is working as well as bluetooth. I have not flashed anything yet. Are these the only steps i would need to follow to get Froyo 2.2.
To install Odin packages on your device
1. First you will need to download and place on your sd card update.zip, download here Update.zip
Download and install drivers on your computer HERE
2. Next you will need a Froyo tar file which will be placed in the PDA section of odin.
Download your flavor of Froyo Below
Full Stock Froyo Leak+root+Froyo Clockworkmod
EB01_DXC.tar
Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod
EB01DB_DXC.tar
3.) You will need to download Odin application tool found here ODIN or ODIN mirror
4.) If your phone is plugged into your computer, unplug it now.
5.) If your phone is not powered down, power it down now.
6.) Remove battery from phone.
7.) Launch ODIN on PC.
8.) Plug USB cable into phone.
9.) Plug your Fascinate into the PC via USB cable.
10.) Press and hold the volume-down key until you see a gigantic yellow triangle and your phone will be in download mode.(Please see 2nd picture in post #3)You can now release the volume key. At this point you will see a yellow com port in the upper left hand corner of the Odin applicate. .(Please see 3rd picture in post #3)
11.) Click on the PDA button in ODIN
Triple check that you pushed the PDA button. Do NOT click the Phone button prior to continuing to step 13. If you choose Phone, you will have bought your Fascinate a one-way ticket to hell.
12.) Choose the .tar.md5 file you downloaded in step 2 above & click the Start button.(this should take approx 3 to 6mins)
13.) Phone will power down when finished.
14.) Remove USB cable.
15.) Reinsert battery.
16.) Power phone and wait to boot approx 4mins
Also would I need to backup data and then wipe before this initial process.
THANKS
