r u up and running? Might be a bad download, or a bad flash of either CWM or your rom your attempting to flash. If not up and running, redownload both the CWM and the rom you want. Odin CWM boot directly to recovery with the 3 finger salute. Wipe the big 3 and reflash the rom. Hope that works!
Got everything up and running now, wiped data, cache, and dalvik, along with the ext4 formatter zip in cwm. I only installed missing apps with data from TiBu, did not restore system data at all, I did get a google services framework fc error upon startup. Next ill run fix permissions in cwm, setup settings in voltage control then wipe my battery stats. Thanks for all the helps guys!
