1. tsargent347's Avatar
    what is a safe temp on comm rom..i watched a couple of videos on youtube, and i noticed the phone started to heat up a little..so i looked into the TSM parts and looked at the battery temp and it said 33 degrees C..is that a safe temp? dont want to fry the phone
    08-21-2011 08:12 PM
  2. tsargent347's Avatar
    Will swtiching to a nonvoodoo kernel help with battery drain and the temp of the phone??
    08-22-2011 01:41 AM
  3. Landshark's Avatar
    My fascinate is at 35 C and runs just fine. You should actually get better battery life with a voodoo kernel because of the switch to the ext4 filing system. I would look elsewhere for the battery drain, some rogue app that is constantly running in the background or possibly a wakelock.
    08-23-2011 10:48 PM
