1. king4367's Avatar
    i got this pop up to update and accidentally hit yes. after that i couldn't use my root apps so im trying 2 get my phone re rooted. everytime i try to root it again it says error device not found
    PLEASE HELP
    10-01-2010 02:21 AM
  2. egg_head's Avatar
    Yes, you lost root.
    Have you looked around for an answer to your question?
    There are several threads filled with discussion on how to reroot after the update.
    [tapatalk on android]
    10-01-2010 07:32 AM
