When I connect to a computer with the USB (I was going to transfer some pics) the touch screen gets all screwy. (Which makes it all but impossible to "mount" to transfer files)
I cannot use it at all. The physical buttons are fine and the, menu, home, back, search buttons work.
Set to Mass storage mode, and no debugging (tried to switch on debugging with no luck)
Unplug USB and everything goes back to working fine
