1. sengokubattosai's Avatar
    Good morning!
    I have a problem with my Fascinate that first started happening after I rooted it last weekend. It's not a HUGE problem as much as an inconvenience, but my battery meter no longer works. It will say it's got a full charge for about 24 hours straight (with my heavy use) then it will beep once and just die with no other warning. Did anybody else have an issue like this?
    12-04-2010 09:08 AM
  2. Cory Streater's Avatar
    Rooting alone will not cause this. What else have you done with the phone?
    12-04-2010 02:19 PM
  3. sengokubattosai's Avatar
    I took off the lagfix and sideloaded the voodoo kernel. Other than that nothing.
    12-04-2010 03:54 PM
  4. Cory Streater's Avatar
    Those are actually pretty big changes. Have you tried a hard reset?
    12-04-2010 04:12 PM
  5. sengokubattosai's Avatar
    No, how do I do that?
    12-04-2010 04:43 PM
  6. Cory Streater's Avatar
    settings > privacy > factory data reset.
    12-04-2010 06:38 PM
  7. sengokubattosai's Avatar
    I don't want to restore factory settings though, I just want my battery life/meter to be normal.
    12-06-2010 10:23 AM
Tags for this Thread
