ferniesp
In this forum, I can only expect that the Samsung users will be the final decision maker for the OP. Go to the X forum and it will be the opposite.
Having used the Samsung for quite some time, I will say without question that it's one of the finest Androids out there. At the end of the day it's all personal preference.
For me, I stayed with the X and this is why.
I believe most would agree that Motorola is king of call quality....that is huge for me because I want a phone first. The Fasinate is good but not as good in this area as the X.
Browser....both are awesome phones in this area. I will stick with the X because of the extra real estate. Most would agree that if you are going to spend an extra 30 bucks a month on data, having a good browser is the number 2 thing that I want on a smartphone.
E-mail on both are good but for some reason, on the 2 Fasinates that I used, my e-mail using Cox would always disappear after a day or so. My X never has this issue.
Battery....this is where I felt the X shined the most. I can go from zero charge to full charge in about 45 minutes and with the Fasinate, it took a couple of hours( good battery life though), I just didn't like the time it took to chage the darn thing. The X would last me the whole day and whats cool with the X, you can use the extended battery with the same stock battery door and no one but you will know you have the extended..which lasts long enough for me.
Build quality is another area and also an important one to consider. I broke the screen on the fasinate by accident trying to get my cover off. I am a strong guy but that thing broke way too easy. Back cover on the fasinate is rediculous. Samsung should have used a more durable material for it. The X is just a solid feeling device which gives you the peace of mind when carrying it around that it won't break on you on the smallest of drops.
In summary at the end of the day, it's your call.
