My home wifi connection is working and I can see the connection available and remembered on my phone. However no matter what I do it will not connect to it. When I select the connection and hit connect it just sits and does nothing. I can get on other wifi access points just fine. I had this problem once before but cannot for the life of me remember what I needed to do in order for it to connect. I am rooted and debloated. I didn't have this problem until I updated the wireless tether app and even after removing it rebooting the phone removing my remembered connection and readding it just wont connect. Again it see's the connection allows me to enter the key (which I am entering correctly) but hitting connect does nothing.
Thoughts or suggestions?
Thanks,
Mike
Thanks,
Mike
