01-30-2011 02:20 PM
342 1234 ...
tools
  1. DroidXcon's Avatar
    Yeah it stays its new with this update
    Ok, I had Google location checked. However, after being unchecked, only the waves disappeared, the diamond icon remained. I guess this is just something that comes along with update then? It isn't a big deal, but it was never on my phone before.
    Sent from my SCH-I500 using Tapatalk
    01-13-2011 03:01 AM
  2. Stain77's Avatar
    Just got my update! I have been checking for it for since Monday nonstop!
    I just tried out the GPS, and what usually took 5+ mins to get a lock was almost instant like 3 seconds! I am a happy camper right now, even though it was not Froyo...
    01-13-2011 03:01 AM
  3. Krook's Avatar
    ok so before i updated i was rooted and debloated. i replaced all the bloatware but left my phone rooted. the update installed fine but when i go to busy box it says im still rooted but when i click install it fails and says: "The application failed, either because your device is not nand unlocked or we were unable to remount. please use logcat at this time, get it from the market"
    when i go to about phone it still says 2.1 update 1. but the capacitive buttons are staying lit. i have the new gps. Im confused ha ha.
    01-13-2011 03:01 AM
  4. Krook's Avatar
    correction.... my build number changed to sch-i500.DLo9. assuming thats the update
    01-13-2011 03:03 AM
  5. DroidXcon's Avatar
    Yes that's the updated build
    01-13-2011 03:08 AM
  6. Krook's Avatar
    What about this?
    01-13-2011 03:09 AM
  7. CarterGuy's Avatar
    It unrooted me but otherwise no problems. Just had to follow these instructions again. http://forum.androidcentral.com/fasc...-how-root.html
    01-13-2011 03:10 AM
  8. Krook's Avatar
    ok i figured it out. im not rooted anymore but bing is still of my phone (te he) my search key routes to vlingo
    01-13-2011 03:12 AM
  9. DroidXcon's Avatar
    This is not a huge change update. Mostly they fixed up and polished up details.. You sound like your good . Just reroot
    01-13-2011 03:15 AM
  10. Krook's Avatar
    yea it just weirded me out that bing still wasnt on my phone after the update. when i hold the search soft key it goes to google still. bing is nowhere to be found in my app screen but its still in my system folder
    01-13-2011 03:19 AM
  11. jbr05ki's Avatar
    LOL sounds like people are geting the update. I just ODIN Flashed to DL09 a couple hours ago too.
    01-13-2011 03:39 AM
  12. ajdroid's Avatar
    So I just got the new firmware ....so obviously I'm not rooted anymore the problem is that while rooting using the above method I keep getting an error saying device not found? although as I type this It seems to be working. should I be worried somethings a miss?
    nope It wouldn't root ..any suggestions?
    01-13-2011 03:39 AM
  13. DroidXcon's Avatar
    So I just got the new firmware ....so obviously i'm not rooted anymore the problem is that I keep getting an error saying device not found? although as I type this It seems to be working. should I be worried somethings a miss?
    You are seeing this on the phone, or on the computer?
    01-13-2011 03:43 AM
  14. ajdroid's Avatar
    On the computer, using dirks ez root v2.
    01-13-2011 03:44 AM
  15. proview3r's Avatar
    got the update... seattle, wa ;]
    01-13-2011 03:47 AM
  16. DroidXcon's Avatar
    throw it in Debugging mode, plug it in and try and let the drivers install themselves
    ajdroid and lherch like this.
    01-13-2011 03:51 AM
  17. Johnly's Avatar
    Samsungs website is gold......just install the drivers before plugging it in.....it is cleaner that way
    01-13-2011 03:54 AM
  18. ajdroid's Avatar
    sorry bout the wait, I uninstalled/reinstalled the usb drivers. I'm gonna try it again. wish me luck lol
    01-13-2011 03:59 AM
  19. ajdroid's Avatar
    Its a no go again same "device not found"error.
    01-13-2011 04:02 AM
  20. DroidXcon's Avatar
    ok try this, with debugging mode on and the phone plugged in Reboot the phone and see if it finds the device
    01-13-2011 04:04 AM
  21. defrogme's Avatar
    Got the update, Buffalo, NY.
    01-13-2011 04:06 AM
  22. Johnly's Avatar
    Make SURE drivers are correct..32? 64? WTF!!!!!
    01-13-2011 04:07 AM
  23. Drootz's Avatar
    Got the update CA
    01-13-2011 04:08 AM
  24. ajdroid's Avatar
    this is what it keeps saying....
    oh and srry if the pics are to big, I cant remember how to re-size them.
    01-13-2011 04:14 AM
  25. DroidXcon's Avatar
    Type
    adb devices
    tell me what it says
    01-13-2011 04:17 AM
342 1234 ...
