FNDomination
Gps waves means its on
Sent from my SCH-I500 using Tapatalk
Ok...but if you pull down the notification bar, my GPS isn't selected as being on...
I am bloody confused...lol
Ok, I had Google location checked. However, after being unchecked, only the waves disappeared, the diamond icon remained. I guess this is just something that comes along with update then? It isn't a big deal, but it was never on my phone before.
correction.... my build number changed to sch-i500.DLo9. assuming thats the update
ok so before i updated i was rooted and debloated. i replaced all the bloatware but left my phone rooted. the update installed fine but when i go to busy box it says im still rooted but when i click install it fails and says: "The application failed, either because your device is not nand unlocked or we were unable to remount. please use logcat at this time, get it from the market"
when i go to about phone it still says 2.1 update 1. but the capacitive buttons are staying lit. i have the new gps. Im confused ha ha.
ok i figured it out. im not rooted anymore but bing is still of my phone (te he) my search key routes to vlingo
So I just got the new firmware ....so obviously i'm not rooted anymore the problem is that I keep getting an error saying device not found? although as I type this It seems to be working. should I be worried somethings a miss?
