DroidXcon
throw it in Debugging mode, plug it in and try and let the drivers install themselves
sorry bout the wait, I uninstalled/reinstalled the usb drivers. I'm gonna try it again. wish me luck lolthrow it in Debugging mode, plug it in and try and let the drivers install themselves
Its a no go again same "device not found"error.
ok try this, with debugging mode on and the phone plugged in Reboot the phone and see if it finds the device
this is what it keeps saying....
oh and srry if the pics are to big, I cant remember how to re-size them.
You are seeing this on the phone, or on the computer?
Thanks for the help, though I seam to have solved my own problem by sheer accident. I guess the media sync being connected caused the rooting process to fail, once I disconnected from media sync it went all the way through albeit, with the same error but, it completed successfully. if anyone else has a similar problem id suggest this as a fix.
how did you disconnect, was the usb setting set up for media player and you changed that or did you just disconnect from the computer and it worked?
I noticed that in the status bar I had the media sync running, as soon as I clicked the disconnect for the media sync on the phone, the root worked. Just like that. I suppose it could be coincidence but it was still displaying the "device not found" error, and just as soon as canceled the media sync it worked.
LOL sounds like people are geting the update. I just ODIN Flashed to DL09 a couple hours ago too.
i was rooted and had the unoffical dl09 and checked could not get the new build. went back to stock and got it right away. just spent the last 6 hours rooting and trying to debloat my phone.. here it goes again by the way i am in westwood. nj and its 5am and dont know y i am up
