disneyland_fan
Not rooted. When first updated, I could not get my phone to mount to my pc. For some reason I can now. I did not do anything different.
After I updated I was getting the media-sync cd-rom drive nonsense as well. I eventually got it working mostly like normal, although I'm not sure exactly what I did to fix it.
The only problem now is that whenever I plug in, I'm asked if I want to download additional software, and it fires up Internet Explorer to a Verizon webpage. Once I close that stuff, it re-detects how I want it to.
Not the biggest problem, but horribly annoying.
Ok, so I'm not a quitter.
Uninstalled the Samsung drivers. Reinstalled with the September 2010 drivers from their site.
Plugged in the phone. Double clicked on the icon in the System Tray to safety remove hardware.
Found the Sansung device. Clicked on it. Clicked the Properties button. Then the Driver tab, then uninstalled the drivers.
Unplugged the phone. Put it in debug mode. Connected the phone again. It auto-detected and drivers were installed.
Opened up Windows Explored. Double clicked the drive assigned to the phone, and there were my files.
For me, it will only work with debug mode on.
Ok, so on another computer I downloaded the Samsung 32 bit drivers from the How To Root post. Installed and everything worked great.
I think it's an issue with 64 bit PC and Mac systems (new macs are 64 bit, right).
Another thing... It only took a couple minutes to install these 32 bit drivers, but on my 64 bit Vista system, the 64 bit drivers take forever to install.
now restart your phone, then plug in your phone, mount. tell us what happens.
I was stock, upgraded to DL09 via OTA straight from Verizon. Still stock, now can't mount. Tried hooking up the cable to my Macbook, shutting the phone down and restarting, that did not work. I cannot get the phone to mount.
It still works, as long as I have it in debug mode. If not in debug mode, the computer acts like I never plugged the phone in,
