Ok, earlier I had the issue with the notification of how many hows until the alarm goes off not showing. Reboot fixed that (even though I rebooted numerous times working on the SD Mounting thing).
Here's what is happening now, and I'm wondering if anyone else if having this issue: When on a call and you adjust the volume up/down, you'll get the popup with an In Call Volume bar moving left or right depending on if you are adjusting up or down.
When not on a call, you'll get the yellow bar to indicate the ringer volume.
I don't get either anymore.
Last week I Odin'ed back to DL01, then OTA'ed to DL09. Then rooted, removed the same bloat I did last time.
Can a couple of you check your phones to see if you have this issue?
