1. m5ivan's Avatar
    I picked up the extended battery and decided to compare the weight to the standard battery. The results are my Nexus with the stock battery weighs 146 grams, with the extended battery it weighs 151 grams. Not a bad trade off.
    Just like many, I find it more comfortable to hold too with the extended battery and cover in place.
    Both covers weigh the same at 8 grams.
    12-19-2011 12:17 PM
  2. S281's Avatar
    will the cover for the original battery fit over the extended battery in place? Or do you have to use the new battery cover?
    12-19-2011 12:43 PM
  3. m5ivan's Avatar
    You can fit the original cover on, but it's not a great fit.
    12-19-2011 01:11 PM
  4. 1fastmr2's Avatar
    How many more mAh does extanded battery have?
    12-19-2011 01:29 PM
