1. flashkillpro's Avatar
    Does anyone know some good cases with build in battery for the VGN like the mophie juice pack air or plus. I searched the internet but didn't find anything like that for the VGN. Here you have the link to the mophie juice pack air for the iphone: mophie juice pack air™ - iPhone 4 rechargeable backup battery case
    12-19-2011 09:15 PM
  2. robstunner's Avatar
    just get some extra batteries. No need for a bulky case when you have the option to remove your battery.
    12-20-2011 04:18 PM
  3. flashkillpro's Avatar
    extra batteries are not easy to transport and you have to turn your phone on and off to change them and you always have to recharge them, ...you cant have them on you in your daily life !
    12-20-2011 04:25 PM
  4. shanimal92's Avatar
    I would really like to know this too. i really like the idea of the Mophie Air for the iPhone. wish they would expand to Android
    12-20-2011 09:08 PM
  5. ultravisitor's Avatar
    Keep an eye on PowerSkin. They don't have a case for the Galaxy Nexus yet, but they do support a number of Android devices, including the Nexus S 4G and Galaxy S II. They may very well have a case for the Galaxy Nexus that is in the works.
    http://power-skin.com/
    flashkillpro and Sauk like this.
    12-20-2011 09:23 PM
  6. Sauk's Avatar
    That looks interesting, thanks
    12-20-2011 11:58 PM
  7. Easton091's Avatar
    Just get the extended battery. My phone is going on 8 hrs off charger at 79% left
    12-21-2011 12:20 PM
  8. flashkillpro's Avatar
    the extended battery gives you 250 mah more then the normal. Thatīs nothing. A case with build in battery gives you 1500 mah to 2500 more so you have :1850 + 2500 =4350 mAh.
    12-21-2011 12:57 PM
  9. jumpo64's Avatar
    Yes, but look at the case for the Nexus S. That thing is a brick even compared to my old OG Droid. I'm all about battery life, but the cases make the phone almost an inch wide.
    If I was going this route at all I'd much rather have an extra 500mAh (plus extended battery) and an overall slimmer phone; compared to 1500mAh extra and a phone I can't get in my pockets.
    In other words I'm willing to sacrifice some of the thinness of the phone, but an inch is way too big.
    12-21-2011 02:17 PM
  10. flashkillpro's Avatar
    im willing to sacrifice som of the thinness too but only s+omething like 2 to 3 millimeters for minimum 400 mAh
    12-21-2011 02:36 PM
  11. dubge's Avatar
    I am not even at 7 hours and have 55% left :-(
    12-21-2011 03:59 PM
  12. Easton091's Avatar
    I was on Wi-Fi
    12-21-2011 07:09 PM
  13. flashkillpro's Avatar
    i still havenīt received my vgn. I only heard about a few people complaining about the short battery because of lte and stuff like that so i cant say i really need a case with build in battery. it is just convenient because you only need to recharge your phone twice a week. I had that on my last phone and it was pretty cool.
    12-21-2011 07:17 PM
  14. flashkillpro's Avatar
    by the way: does anyone have a glowing case for the vgn ? like the ones that glow in the night ?
    12-21-2011 09:19 PM
