1. Big_Holmes's Avatar
    Anyone know of a good horizontal belt loop holster that might fit my Nexus with a Diztronic TPU case on it ...
    http://www.amazon.com/gp/product/B00...cUvbUpU1533750
    Need something with a clip and loops for added security...I've always loved the Luxmo holsters but not sure whether or not my phone with both an extended battery and case would fit
    01-04-2012 08:28 AM
  2. UBChain's Avatar
    I got this one for my GNex w/ a Body Glove case on it. I had the same mfg belt case for my Dinc and LOVED it. So far, so good on the one for the GNex.
    Big_Holmes likes this.
    01-04-2012 08:49 PM
  3. samkatz's Avatar
    tx for posting.
    Do you know how many inches wide this is? I'm using this caseClip Case Sideways | Nite Ize which measures 5.5"
    I like it but the GNEX in my incipio case *barely* squeezes in. The sides expand but it's still a bit to tight.
    tx.
    01-04-2012 09:31 PM
  4. Big_Holmes's Avatar
    Appreciate it. I've always loved their products for all my phones
    01-05-2012 11:46 AM
  5. kph3's Avatar
    I am using the Verizon horizontal leather case with a Diztronic matte tpu case and it works pretty good. No belt loops, but it hasn't been a problem for me yet.
    01-07-2012 12:28 PM
  6. Hondo_Lane's Avatar
    I'm using the OEM Shell Holster with the TPU Case (extended batt) and it fits and works very well.
    http://www.amazon.com/Samsung-Galaxy-Holster-Kickstand-Retail-Package/dp/B006OM79K2/ref=sr_1_1?ie=UTF8&qid=1326063915&sr=8-1
    01-08-2012 05:06 PM
  7. bdnyy23's Avatar
    Not sure if you are still looking, I just ordered this one from amazon as I read the one review that it fit with a case and extended battery. Will update once I receive mine. Hoping it will work with the Incipio Dual layer case on and extended battery. http://www.amazon.com/EMPIRE-Samsung-Galaxy-Leather-Packaging/dp/B006LR57M2/ref=sr_1_3?ie=UTF8&qid=1326131198&sr=8-3
    01-09-2012 11:49 AM
  8. samkatz's Avatar
    thank you. Looking forward to hearing if it works for you
    01-09-2012 12:47 PM
