Re: [GUIDE] Galaxy Nexus MOD/Palm Touchstone-No soldering on phon
Ok. I have some more useful tech data to add. This is for folks who want to be able to use Force Fast Charging (FFC) or AKA AC Charging mode on the touchstone in their cars primarily. But it also applies to people trying to use non-OEM wall chargers as well.
Ok so I am not sure where to begin this rant so I will just word vomit it out. If you want to use the Touchstone in your car the charger/cable you use is important depending on which charging mode you want to utilize.
Background info:
The TS needs more current to function than a lot of chargers can provide - which is why they tell you not to plug it into your computer and why it won't work with a lot of chargers. I am going to tell you why and how to work around or avoid the problem. If you do not have enough current to the Touchstone it will do a weird on/off/on/off dance. The touchstone looks for a charger/cable combination that indicates the data pins D+ and D- are shorted together - this is used by the USB Spec to indicate a charger that is capable of providing >500 mA. If you do not have this, then the touchstone will not work at all. This is done internally for the OEM Palm Chargers. If you have an amperage-capable charger you can short the pins together yourself and it will work ***however*** it depends on which mode you want to charge with. There are two modes, USB Mode (slow - ~ 450 mA to phone - sometimes inadequate) and AC Mode (fast ~ 650 mA to phone - much better but not as good as a good car or wall charger plugged in directly ~1000mA).
If you are just wanting to charge your phone in USB Mode on the TS: my 850 mA Motorola Car Charger is adequate. I am guessing that you need at least a 650 mA rated charger. Remember it must have D+ and D- shorted to work at all.
If you desire to use AC Mode on the TS: You need a charger capable of 1A. My 850 mA Moto Car Charger just causes the TS to on/off/on/off every few seconds. Remember even if the charger is rated for 1A it must have D+ and D- shorted to work at all.
Here is a list from the WebOS forums that lists working CAR and WALL chargers for the TS:
Here
For my Car TouchStone -I have purchased the Palm Car Charger 3453ww which is 1000ma rated from Amazon for $12. This already has D+ and D- shorted internally.
Here @ Amazon Plus its OEM so quality of the power delivered will most likely be much cleaner.
I hope this is useful to folks who can't get it working in their car especially with the FFC (AC MODE) mod going. If you're seeing an on/off dance with the touchstone you are using an inadequate car/wall charger.
