ellesshoo
This mod looks very simple!! I just have a question about voiding the warranty. Does this void the warranty because you need to open your phone? I ask this because I see no stickers around the housing for them to know that the housing was opened.
As long as you don't solder the strips to the pogo pins I see no reason why this mod couldn't be undone for warranty replacement.
Am I missing something?
I wish I could answer this for you but in all honesty it just doesn't matter bc there is really no indicator to trip by opening the phone. If you have a small diameter soldering tip I'd even recommend to go ahead and solder in the phone (a desolder wick with a little flux will clean it up like nothing ever happened if you need to reverse the mod).
