1. tony bag o donuts's Avatar
    has anyone used the standard battery with the extended battery case?
    I am going to be photographing an all day event and don't want to carry two phone backs with me.
    I have a portable xcel usb charger, but wanted to still make use of my standard battery.
    Thoughts?
    I was thinking of using a folded business card to hold it if it wiggles....
    03-11-2012 09:22 AM
  2. Droid Brick's Avatar
    I believe Phil mentioned that the standard battery fits in there just fine with the extended battery cover and does not wiggle at all. While I've been meaning to try it I've never needed it.
    03-11-2012 10:19 AM
  3. tntdroid's Avatar
    I have no issues doing this. Mine has never came out or anything.
    03-11-2012 10:57 AM
  4. turdbogls's Avatar
    I got it to stick just fine, but I don't know if it would last all day that way. It was a tight fit, plus it just felt funky.
    My suggestion is to use the extended battery cover with both and just get something to wedge the standard battery in there so it doesn't move.
    03-11-2012 11:58 AM
  5. pimfram's Avatar
    I've tried it before, and it does fit. Not sure how well it would stay on since it kind of bows out a bit.
    03-11-2012 12:04 PM
