[GUIDE] Return to Stock: Factory Images for the VZW Galaxy Nexus
Apr 26, 2010
4,335
258
83
ok..mouze was trying to help me out.
I screwed my device up.
I am up and running and verizon updated it's software.
So now I have unlocked bootloader with 4.1.1 from verizon but lost root.
Can't use wugs because it says no fastboot device found.
I need help because I can't even enter the bootloader to flash su.zip. I get the red triangle with ! in the middle.
draconos
10
sniff sniff had to do this today for my Galaxy Nexus. Alas it did not survive the drop from my pocket to the ground in subway and had to be replaced. At least I have a shiny new Galaxy S3....
DroidXcon
11,102
3,392
Hey guys, ok so i get to this command
fastboot-windows ?w update image-mysid-jro03o.zip
then under it says
usage: fastboot []
and gives me a list of commands and options:
im sure its something obvious that im doing wrong , any help appreciated, thanks
Edit-
Nevermind found my answer. Thanks anyway
davey11
2,203
508
113
then under it says
usage: fastboot []
Edit-
I had that same exact problem and I was copying and pasting the command. When I typed it in, boom it went through. Strange.
Sent from my mako :)p)
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
then under it says
usage: fastboot []
Edit-
I know it's a bit late, but that one must always be typed out manually, not copied and pasted.
jeneral2
