Hey everyone, first post here - I just picked up my first Android device (Verizon Galaxy Nexus) and I'm PSYCHED to get this thing going with some custom stuff!
Anyways, first thing I did was the fastboot oem unlock, then rooted using SuperBoot. When I went to flash CWM Recovery, fastboot gives me the following: "error: cannot load [img filename]" (where [img filename] is whatever image I typed in). I've ruled out the possibilities that this is due to a file naming problem, file extension, upper case/lower case, etc. Also the image is in the same directory as fastboot. I've tried renaming the image to something simpler like "recovery.img" but that doesnt work either - it's like fastboot simply can't find any images.
Any ideas? I'm completely stuck as of now. Thanks in advance!
