Ok the MOD is back up on a new file share site. Here is what you will need to do. First download the file to your computer. It will be a file called eri.xml. Once you have it loaded then from your phone go into root explorer. Go into system/framework. The click up top on the Mount R/W box so you can Read/Write. Find the file framework-res.apk. Hold down the file and click copy. Now back up to the main screen and go into sdcard. Fine a folder like download and click on it. Then hit the past button. Back out and plug your phone into your computer. Go into the folder that you put the framework in. Find the file and copy to your computer. Now right click the file and open with 7-zip. Once open in 7-zip double click res then xml. You will see a file called eri.xml. Now take the one you downloaded from the link below and drag it into the work space. You want to over write the file with the new one. Close up 7-zip and then drop the edited framework-res.apk back onto your phone. Now go into sdcard find the new file and copy it. Back up and go into system/framework again. Make sure your still in R/W and then hit paste. You will be told your going to over write and click ok. Every time I do this my phone just reboots right then. If not then manual reboot the phone. You should now see the Verizon Wireless is removed from you lock screen and drop down. Enjoy.
No Verizon - http://www.mediafire.com/?ljt6eu8p5am9o0d
